Webex Video Endpoint Mounting Height
scott_brewer1
What is the preferred mounting height for your Webex Video endpoints in a conference room
Project workspace covers  a lot regarding the Cisco Video Endpoints and conference rooms designs. Go through the project workspace and you can Access  PW  from https://projectworkplace.cisco.com
Response Signature
Matt_W
Level 3
Level 3
It really depends on the environment.  Preferably you want it around 5-6 ft (around eye level), but depending on the screen size and room layout it may need to be slightly higher or lower.  Check out the installation guides for Cisco's recommendation based off each device.  Check out this one from the Room Kit https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/room-kit/installation-guide/cisco-webex-room-kit-installation-guide-multilingual.pdf
If you're trying to design the perfect room layout this is also a great general resource for Cisco devices: https://www.cisco.com/c/dam/assets/sol/tp/workplace_app/assets/pdf/best-practice.pdf
Recommended Mounting height are mentioned in  installation guides. Refer Installation Guide for your  Device. Installation guide for all devices are available on  https://www.cisco.com/c/en/us/support/collaboration-endpoints/spark-board/products-installation-guides-list.html
Response Signature
