08-29-2022 11:18 AM
Registration: | Registered with Cisco Unified Communications Manager CUCM-PUB |
IPv4 Address: | 10.41.17.82 |
Active Load ID: | sip8845_65.14-1-1-0001-125 |
Inactive Load ID: | sip8845_65.12-1-1-12 |
Download Status: | Failed |
Requested Load ID: | sip8845_65.11-3-6MPP0001-273 |
Download Server: | 10.41.1.10 |
Inactive Load Failure Reason | File Not Found |
Anyone have this error, only a couple fo our phones didn't upgrade. they both say File not found, only 2 out of 60 had this issue. we have them plugged in spots where phones did successfully migrate.
08-29-2022 07:05 PM
Do you have that firmware on your TFTP server of 10.41.1.10? Or are you using the "Load Upgrader" field on those phones? If that looks good sometimes a factory reset will reset the phone to upgrading correctly.
09-22-2022 10:07 AM
thanks fo reply, we tried both. just think it was bad phones. all other migrated ok
