Does WebEx Calling Support a front door phone for visitors?
danieldurham
Vaijanath Sonvane
Hi @danieldurham,
You can use one of the supported Cisco Phone with wall mount kit as a front door phone for visitors. As @dtibbe mentioned, third party phones will be supported soon.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
dtibbe
Check the list of supported devices at https://help.webex.com/qkwt4j/
Currently, only Cisco phones are supported. There are plans to support other 3rd party devices as well, think the latest plan was for Q4CY21..
