In WebEx Calling, Between Different Organizations
THOMAS CARROLL
Can Calls be made via Dialing E164 numbering between WebEx Organizations without Egress/Ingress PSTN connectivity?
dtibbe
Nope. Inter-Org-Calls are always routed via PSTN.
Dennis1432
Only inside the same domain, calls will route internally, if call is from Domain A to Domain B, it has to route via DID.
Mohammed-A.R.A
Correct. Inter-Org-Calls are always routed via PSTN.
Its your carrier/PSTN provider who owns the number and they will route the call.
It depends who is offering PSTN services. It can be through local gateway, Cisco provided PSTN service or partner provided PSTN service.
Vaijanath Sonvane
You can use local gateway between two Webex Calling organizations to allow Inter-Org-Calls.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
dtibbe
