Local Gateway registration issue with Webex calling
Hello Experts,
We have 2 Cube in a different location connected to Webex Calling, the first cube is registered and working fine, and the call is fine also.
But when we configured the second cube with the same configuration it doesn't register nor send the registration message to Webex  and gave us on the logs the below :
000573: *Jul 11 05:49:43.009: %SIP-5-TLS_CONNECTION: Connection successful for addr=139.177.71.10, port=8934, connId=245
000574: *Jul 11 05:50:00.777: %SIP-5-TLS_CONNECTION: Connection failed for addr=139.177.71.10, port=8934, connId=245
000575: *Jul 11 05:50:01.086: %SIP-5-TLS_CONNECTION: Connection successful for addr=139.177.71.10, port=8934, connId=246
000576: *Jul 11 05:50:18.844: %SIP-5-TLS_CONNECTION: Connection failed for addr=139.177.71.10, port=8934, connId=246
000577: *Jul 11 05:50:19.157: %SIP-5-TLS_CONNECTION: Connection successful for addr=139.177.71.10, port=8934, connId=247
000578: *Jul 11 05:50:36.919: %SIP-5-TLS_CONNECTION: Connection failed for addr=139.177.71.10, port=8934, connId=247
000579: *Jul 11 05:50:37.225: %SIP-5-TLS_CONNECTION: Connection successful for addr=139.177.71.10, port=8934, connId=24
Thanks in advance.
BR,
Mohamed Saber
Thanks all , after deep investigation we found that the credential number (in webex tenant) was wrong , after adjust it , the cube registered successfully.
Vaijanath Sonvane
Hi Mohamed,
Is it possible for you to attach configuration files of both your CUBE routers?
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Right, would be helpful if they differ.
Please **** your passwords
dtibbe
By same configuration, do you refer to the whole same configuration? Or do they have different credentials?
