New Cisco phones not working in Webex old firmware?
New Cisco phones not working in Webex old firmware? Do I need a special model? I never had this issue in the past where I can add in webex via mac address and after I factory reset it does not get pick up also firmware seems like it is old
Vaijanath Sonvane
Hi @Vincent Lobaccaro,
CP-8861-K9 will not work out of the box with Webex Calling. These are meant for CUCM environment. There are now two options:
1. Replace these with CP-8861-3PCC-K9 or
2. Convert CP-8861-K9 from Enterprise Firmware to Multiplatform firmware using below procedure:
https://www.cisco.com/c/en/us/support/docs/smb/collaboration-endpoints/cisco-ip-phone-8800-series/1534-Conversion-enterprise-phone-to-mmp-or-vice-versa.html
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
the old ones are cp-8861-3pcc-k9 v12
The new ones are cp-8861-k9
Vaijanath Sonvane
Make sure these phones are Multiplatform Firmware (MPP) models (3PCC-K9). It is mentioned on back of the phone.
