10-24-2023 08:44 AM
New Cisco phones not working in Webex old firmware? Do I need a special model? I never had this issue in the past where I can add in webex via mac address and after I factory reset it does not get pick up also firmware seems like it is old
Solved! Go to Solution.
10-24-2023 10:24 AM - edited 10-24-2023 10:25 AM
CP-8861-K9 will not work out of the box with Webex Calling. These are meant for CUCM environment. There are now two options:
1. Replace these with CP-8861-3PCC-K9 or
2. Convert CP-8861-K9 from Enterprise Firmware to Multiplatform firmware using below procedure:
10-24-2023 09:42 AM
the old ones are cp-8861-3pcc-k9 v12
10-24-2023 09:41 AM
The new ones are cp-8861-k9
10-24-2023 09:21 AM
Make sure these phones are Multiplatform Firmware (MPP) models (3PCC-K9). It is mentioned on back of the phone.
