Webex Calling - Extended Away Feature
lisa_lennon
Is there a way to control whether or not a voice mailbox receives messages while in Extend Away?  Right now the only option blocks the mailbox from receiving messages.
lisa_lennon
This is not a great workaround.  But thank you for the reply.
dtibbe
You could disable the VM service for your user. There are also checkmarks for when to have the VM service answering your calls, ie. when busy, no answer, or always.
Check the settings for your user in your user portal via https://settings.webex.com/ -> Calling (or your company's myphonenext-Page)
