12-12-2023 10:26 PM
Hello Everyone,
Can I use the Webex calling function on Teams without having to install the webex application on my computer/phone?
Thank you in advance.
Enrico
Solved! Go to Solution.
12-13-2023 03:22 AM
Hello enricos,
Best regards
******* If This Helps, Please Rate *******
12-13-2023 06:18 AM - edited 12-13-2023 06:19 AM
Nope. There is no SDK from MSFT to replace/substitute the telephony functionality in their client executable. The only options are the cross-launch that Cisco supports or implementing the MSFT Phone System as a second PBX - with all the design considerations that entails - and using Direct Route to steer calls between it and another PBX. Some UCaaS vendors have implemented support for this but it’s the most expensive and complicated deployment option. Cisco has thus far abstained from supporting that mess with Webex Calling for, IMO, understandable reasons.
12-13-2023 04:54 PM
Thanks all for the help.
12-13-2023 03:22 AM
Hello enricos,
Best regards
