Webex calling on Teams
enricos
Visitor
Hello Everyone,
Can I use the Webex calling function on Teams without having to install the webex application on my computer/phone?
Thank you in advance.
Enrico
2 Accepted Solutions
Blue_Bird
Hello enricos,
  • Users must have Webex App and Microsoft Teams installed. For the Webex Calling for Microsoft Teams integration to work with the Unified CM call control backend.
Reference: https://www.cisco.com/c/en/us/support/docs/conferencing/webex-control-hub/220504-deploy-and-use-of-webex-call-integration.html
Best regards
******* If This Helps, Please Rate *******
Jonathan Schulenberg
Nope. There is no SDK from MSFT to replace/substitute the telephony functionality in their client executable. The only options are the cross-launch that Cisco supports or implementing the MSFT Phone System as a second PBX - with all the design considerations that entails - and using Direct Route to steer calls between it and another PBX. Some UCaaS vendors have implemented support for this but it’s the most expensive and complicated deployment option. Cisco has thus far abstained from supporting that mess with Webex Calling for, IMO, understandable reasons.
enricos
Visitor
Thanks all for the help.
Blue_Bird
Hello enricos,
Best regards
