06-21-2023 07:14 AM
After making a change to device defaults in Control Hub, it tells me to resync the devices. I CANNOT FIND any option to do this regardless of looking everywhere I can think of to do so. I'm somewhat frustrated as this really is something that should be front, center, and obvious.
Can anyone tell me how to access the resync function to update the devices with the new defaults?
09-23-2025 11:23 AM
I know this is an old thread, but you'll be happy to know that Cisco is finally making this a reality.
https://help.webex.com/en-us/article/rdmb0/What's-new-in-Webex-Calling#id_121730
Go to the "Coming Soon" option towards the top and you'll see this:
Administrators can bulk resync devices on demand from the Device tab in Control Hub. Only devices that are SIP-registered and active are eligible for resync
11-22-2023 12:00 AM
Is there a way to do "Apply Changes" or "Reboot" devices on a location level? If you have 1000 devices, how is this going to take effect on all devices without going on each device?
06-21-2023 09:36 AM
On the device page...click Actions and you can "apply changes" or "reboot".
03-25-2024 03:36 AM
Nope, not really. This works for ONE device. What about a thousand devices? What about an entire location? You simply cannot do that. And that's a BIG issue honestly.
03-25-2024 08:59 AM
Check out Anthony's TamperMonkey script: https://github.com/avholloway/ch-wxc-bulk-apply-reboot
There are several other cool scripts in his GitHub repo
12-09-2024 05:11 PM
While I really NEED this tool, and tried my best to make it work, it doesn't (at least for me). It throws all kinds of errors at me, and since I'm not experienced in programming tampermonkey scripts, it becomes basically useless to me. This could well be user error. Tools like this are wonderful. They are even better when there is clear documentation available showing how to set them up and use them. I got tampermonkey installed, and got the script installed. I see the reset phones and apply config buttons appear. But pressing one simpley throws errors at me (using the Developer tools window.....which I also barely know how to use and could be using wrong)...
