WebEx Calling Voicemail PIN Templated
CPriego
hello
I have 5 different locations configured on WebEx Calling
how do you configure a VM template per location and a default VM PIN?
could it be set to match the user's extension? if not, how could you set it to a default VM PIN that the user has to change after the first login?
thanks
dtibbe
Check https://help.webex.com/npafdh5/
A default VM pin may only be specified per org, not per location
Vaijanath Sonvane
Hi @CPriego,
It is not possible to setup Voicemail PIN per location. Voicemail PIN can be setup per User or at organization level.
  • To setup PIN at organization level, please follow the URL mentioned by @dtibbe. It is recommend that the user create their own PIN on settings.webex.com. However, if you choose to enable this option, let users know what their default PIN is. They'll need to reset their PIN using their phone or calling app before they can access their voicemail.
  • To setup PIN at User level, then go to User >> Select User >> Calling >> Voicemail >> Reset Voicemail PIN
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
dtibbe
thank you.
for the prompt response,
we will make it work per org. thanks, again
