Deskpro - assign a device configured in MTR to a user
jperez2
With the October beta release, you can assign a device in MTR to a user.
I have set it up, but I run into the problem that the touch screen on the Microsoft side does not work.
If I can access the webex menu on the right hand side
George Sotiropoulos
Please could you be a bit more specific?
What type of Cisco Device you use, also are you referring to a Touch Navigator (can you specify the SKU)?
Are you aware of the following?
https://www.cisco.com/c/en/us/support/docs/field-notices/740/fn74039.html
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
