Jabra Speak2 mute button not compatible
lskokan
Is there any way how to fix mute button on Speak2 and Webex? Old Jabra speak used to work
5 Replies 5
Max Jobs
Try to test it on new/clean OS.
Max Jobs
Hey lskokan...
Here is a list for supported headset.
  • Jabra Speak 410
  • Jabra Speak 450 Cisco
  • Jabra Speak 510
  • Jabra Speak 710
  • Jabra Speak 750
  • Jabra Speak 810
  • Jabra Speak2 40, 55, 75
https://help.webex.com/en-us/article/nrivbbab/Webex-App-%7C-Details-about-headset-support#reference-template_4097e905-9111-4042-bf63-8f3f5465048b
yes, Jabra Speak2 40  I have works with Webex, but the mute button does not. Previous Jabra Speak version did work fine
Just a simple question. Did you reinstall Jabra software? I had the same issue with Plantronics headsed, so I reinstalled HUB app and problem solved.
yes, I did. I refreshed firmware as well and there is no change
