Room Bar Pro - MS Teams Room
ErikF
We have a new Room Bar Pro and we're having an issue setting it up as Teams Room device.  No matter what software version we're running - there is no option during the initial setup wizard to choose Microsoft Teams Room as the documentation says there should be.  The only option we have is RoomOS/WebEx.  Is there a special version or license key needed to do this?  The device is listed as Teams Certified but the only way we can find to join Teams meetings is via Webex subscriptions that we don't have.
ErikF
I ended up opening a TAC request and they sent me a private download link for the 11.6.1.5 version which did allow me to select Teams Room during the initial setup wizard.   After registering it with Teams, I was able to push out the latest version and everything's working well now.  No idea why the download links are not otherwise available, though.
7 Replies 7
NasPham
I had to modify one of the update channels in Control Hub to use a RoomOS from earlier this year, and then set my device to that update channel. I applied update right away and rebooted. Once it rolled back the RoomOS version number, I was able to register the device as a MS Teams device.
ErikF
sometimes I also run into the issue where firewall rules are blocking downloads from the Webex Cloud.  https://help.webex.com/en-us/article/WBX000028782/Network-Requirements-for-Webex-Services
Adam Trenkler
would this be any help to You ?
https://www.youtube.com/watch?v=Y4na4YHr6zA
I'm working with my IT Security as we have some options blocked in Azure politics... and our Desk won't register properly....
but I do see the option to register it as MTR.
Jonathan Schulenberg
Minimum RoomOS version for MTRoA on a Bar Pro is 11.6.1.5. What version are you running?
https://roomos.cisco.com/doc/MTR
It came with an older version of 11.5.x but I've tried 11.5.4.6 and 11.9.2.4. These are the only two versions that seem to be available from software.cisco.com.
If you click to register to Webex cloud it should download the latest version of the software before you need to plug in a 16 digit registration code.  Once the new software is installed, you should have the option to back up and pick to use the MTR OS instead.
