Room Bar Pro USB Driver
Seoulhawk
We are considering purchasing some Room Bar Pro systems. Our issue is that we have users that will BYOD and want to use MS Teams. What we need to know is when the user plugs in the USB will they be prompted to install a driver or will it use standard windows drivers? Users do not have admin rights, so it needs to be seamless.
As @PJMack mentioned, no drivers need to be installed and it will use inbuilt windows drivers (assuming you're on a relatively current version of Windows).
Note: the Room Bar Pro can also be registered directly as a MS Teams device if MS Teams is your chosen platform.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
PJMack
Level 7
Level 7
It should use standard windows drivers. We have hundreds of users using the desk series with USB passthrough and drivers have never been an issue, this should behave the same.
