Signal and call flow for Webex room device registratered on Cloud
mangesh084
What will be call and signaling flow for room device which is registered on WebEx in following scenarios.
Assigned Public IP and registered on WebEx cloud.
NATed with Public IP and registered on WebEx Cloud.
Mike_Brezicky
First, I would like to mention its not really recommended to have the room kit configured with a public IP, and NAT is not necessary. A Room kit registered to webex cloud will have full functionality with an internal address. If external / B2B calling is needed, you should look into an expressway setup, and that is where the public IP should reside.
For your question though, as Webex is in the public cloud, both scenarios will have the signal / media connect to the webex cloud. For the NAT'ed device, as long as your SIP Inspection is running properly, it should be handled the same.
Please review this doc for Network Traffic and IP ranges for webex -https://help.webex.com/en-us/WBX264/How-Do-I-Allow-Webex-Meetings-Traffic-on-My-Network
Mike_Brezicky
