Generic Webex URI with host pin embedded?
nathanaelb
Level 4
Level 4
Is it possible to dial a Webex meeting as a host with the host PIN embedded into the URI?
ie.   123456789.4444@webex.com
Also is there a generic Webex URI that allows you to hit a lobby and enter a Meeting Number?
Mike_Brezicky
I do not believe the PIN can be added if calling using a SIP URI. It can be done if just calling via telephone.
For the lobby, the SIP URI is meet@<sitename>.webex.com.
meet@webex.com might be working now as well with the short URI dialing.
