3600 8 SSID Limit
tpahuja
Folks,
         Can someone please tell me why there is a limit of 8 SSIDs on the ac module of a 3600 series AP.
"Only the first 8 WLAN IDs are advertised on the 5-GHz radios regardless of the ID number"
Jurgens L
Level 3
Level 3
It comes down to hardware limitation, the 802.11ac Radio Module for the 3600 series was the first 802.11ac (Wave1) solution Cisco provided before they released the 1700/2700/3700 series AP's that comes standard with these features building in.
This is normally the problem you have with a product that provides a new technology (at that time) released early into the market.
### Rate Useful Posts Please ###
Jurgens L
Level 3
Level 3
this is also by software design
WLANS are sent out each with its own radio MAC address
each AP can send out max 16 WLAN's / SSIDs
each 2,4GHz SSID from base radio MAC address + WLAN index
each 5GHz SSID from from base radio MAC address + 16 - WLAN index
so technically you may be able to send out 16 ac (5GHz) SSID's, but processing power may pose extra limitations
