12-11-2018 01:00 AM - edited 07-05-2021 09:33 AM
Hello everyone,
My 3 air-ap1815w-E can join the wlc 2504 controller without problem, but not my air-CAP702W.
the log from the CAP702W:
Solved! Go to Solution.
12-14-2018 12:20 AM
12-11-2018 01:46 AM
according to compatibility sheet (https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.pdf) 700 series supports with 8.5.131.0 after 15.3(3)JF7 AP OS. as i see you have autonomous ready Hardware SKU AP (AIR-CAP702W). in this case check the OS type is autonomous or LWAPP. you need LWAPP (https://software.cisco.com/download/home/286250957/type/280775090/release/15.3.3-JI1) OS to join with WLC. in that case you may need to reimage AP with LWAPP OS.
good luck
12-11-2018 04:02 AM
the air-cap702w seems already with the lwapp os type:
12-11-2018 08:15 AM
can you try with LWAPP recovery image in download section?
12-12-2018 01:55 AM - edited 12-12-2018 01:56 AM
12-12-2018 08:20 AM
12-12-2018 09:06 AM
I have tried the image recovery and the manual configuration for wlc on the ap nothing changed.
12-12-2018 06:33 PM
12-12-2018 11:40 PM - edited 12-12-2018 11:44 PM
12-12-2018 11:46 PM - edited 12-12-2018 11:46 PM
12-12-2018 11:46 PM
12-13-2018 01:07 AM
12-13-2018 01:08 AM
12-13-2018 03:09 AM
12-13-2018 03:58 AM - edited 12-13-2018 04:03 AM
