07-23-2020 02:46 PM - edited 07-05-2021 12:19 PM
I have some questions regarding 1832i as Master ME
HW INFO
ME 1832i Fimware 8.5.161.0
1. when I ssh using putty 0.74 to AP. It always shown "login as" first
Solved! Go to Solution.
07-24-2020 06:05 AM
07-24-2020 06:05 AM
07-24-2020 05:41 PM - edited 07-24-2020 05:44 PM
2. What I mean if I forget GUI or SSH password on ME Controller.
Can I reset the password without factory reset which will loosing all configs.
What I can think is by cancelling Autoboot and type something there
That how to reset password on Unix. I think it should be the same method on ME
1. I'll try when I get latest fw
3. haven't found peer-block on my old GUI. I'll check on latest fw
CLI
4. found the answer here
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/release_notes/b_ME_RN_810.html
but haven't found upgrade path for 8.10 in the release notes
5. need to check on latest fw
07-25-2020 01:01 AM
07-25-2020 06:30 AM - edited 07-25-2020 06:31 AM
I found this solution on youtube
Don't cancel autoboot on Controller
User:Restore-Password
Enter User name: admin2
Enter password: ********
Reenter Password: ********
User: admin2
Password: ********
On "Enter User Name", create a temp admin account, but don't use existing user a/c
Once you login using temp admin a/c. You can reset existing user a/c from GUI
Nawir
http://goo.gl/lhQjmU
http://nbctcp.wordpress.com
07-25-2020 08:45 AM
07-25-2020 03:47 PM
07-27-2020 02:37 AM
07-28-2020 06:07 PM
07-29-2020 08:53 AM
