02-09-2015 11:57 PM - edited 07-05-2021 02:28 AM
Dear All,
I have a AIR-AP1131AG-E-K9 configured with 2 SSID. i have configured 4 different key for Guest SSID (Vlan 30) but am not able to connect my laptop using any of the key
Can you suggest me
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 20 mode wep mandatory
encryption vlan 30 key 1 size 128bit 7 CE78330C1A841439656A9323F25A
encryption vlan 30 key 2 size 40bit 7 1ED10A3EC081
encryption vlan 30 key 3 size 40bit 7 AC64A10F447B transmit-key
encryption vlan 30 key 4 size 40bit 7 203EC038BBEA
encryption vlan 30 mode wep mandatory
Solved! Go to Solution.
02-10-2015 10:30 AM
Why do you want to do WEP (no longer secure, can be crack in minutes). Also note that latest client may even not support this method for security reason.
Use WPA2/PSK instead. Refer this link if you want configuration assistance
http://mrncciew.com/2013/03/02/autonomous-ap-with-wpa-psk-security/
Rasika
**** Pls rate all useful responses ****
02-10-2015 10:30 AM
Rasika
02-11-2015 08:01 AM
I totally agree with Rasika.
I would not recommend to use WEP at all, I suggest you to use WPA instead
02-19-2015 06:19 AM
Dear ,
With the below config, one of my laptop doesn't connect (see) to Data SSID even i configure manually
Can you suggest me why it is? how to solve the problem
dot11 ssid Data
vlan 20
authentication open eap EAP
authentication network-eap EAP
dot11 ssid Guest
vlan 30
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 7 002B110B24705B0B5B
bridge irb
no ip address
no ip route-cache
encryption vlan 30 mode ciphers aes-ccm tkip
ssid Guest
mbssid
station-role root
interface Dot11Radio1
no ip address
no ip route-cache
ssid Data
no dfs band block
channel dfs
station-role root
02-19-2015 01:22 PM
Britto,
1) The SSID Data does not have the "guest-mode" therefore the SSID name won't be broadcasted on the beacon frame
2) I am assuming you are not including all the configuration here. The sub-interfaces on the radios for the VLANs are missing.
3) You are still using WEP, why not WPA?
4) Assuming again, your laptop might not be dual-radio, therefore it can't connect to 5Ghz frequency. Can you confirm if your laptop supports both 2.4Ghz and 5Ghz ?
