Radius Authentication with aironet 1140
visionsystems
I try to setup a 1141 aironet AP to authenticate my user through our Ms Radius Server ( Win 2008 R2).
Everything is fine with small Bussiness AP WAP4410N with the following configuration:
But I can't setup successfully the aironet 1141 with the same settings and getting it works.
Here is my configuration for the Aironet 1141
Vlan 1 is the ssid I want to get it work with Radius.
Security settings :
With this configuration I get the following error on the Radius server:
Thanks for help
visionsystems
by using the Express Security section, I get the correct settings to get it work.
