09-26-2018 07:28 AM - edited 07-05-2021 09:13 AM
Dear All
I have two wireless controller model 3504 we need to configure redundancy for primary and secondary . i have total 26 access point and two controller 15 AP license installed .i want all AP working with one controller at a time once primary is down then add automatically secondary controller .we can install 30 license (15+15) the WLC1 and WLC2 it will work or not ?
Please update ASAP
Muhammed Hismath vk
Solved! Go to Solution.
09-26-2018 02:56 PM
As per Cisco doc, 3504 acts the same as any other big wlc like 5500 or 8500. Which means, to have HA AP SSO, you must have one wlc with the total number of AP licence, in your case 26, and a second default HA-SKU controller
With zero licensing. HA-SKU is meant to be standby WLC.
Whenthe primary goes down, the standby wlc henritage the total licensing.
If you have two wlc working independently, as looks like is your case, and now you want to create a cluster, the standby WLC must have at least 50 AP licensing otherwise they won't join as a cluster.
In you scenario you can't transfer licensing as you don't have a standby wlc as HA-SKU or at least 50 licensing. They will work independently and with the AP licensing they have, which means, you can't transfer all the AP to one WLC if one wlc goes down.
-If I helped you somehow, please, rate it as useful.-
09-26-2018 02:56 PM
09-26-2018 11:39 PM - edited 09-27-2018 01:45 AM
09-27-2018 01:46 AM
Thanks All
09-26-2018 03:00 PM
