05-11-2015 07:57 AM - edited 07-05-2021 03:12 AM
I need to failover so we will move all ap's from WLC1 to WLC2. My issue is that exist 2 HA config:
- Global: Wireless> Global Configuration
-Local: Wireless > All APs
What have more priority the local or global?
05-11-2015 11:16 PM
Hi Alfredo,
Local AP HA tab has the first priority.
All APs > Details for AP01 and then HA tab.
Don't forget to rate helpful posts
05-14-2015 08:50 AM
I know that the local config has override. But how could I do that global config has more priority without outage?
05-13-2015 03:29 PM
Please refer to the below link for the information on Wireless LAN Controller Fail over Priority :
https://supportforums.cisco.com/document/17171/how-configure-wlan-controller-failover-lightweight-access-points
Please let me know If the solution is helpful
07-06-2015 08:38 AM
Hello Alfredo,
Please check the below links
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01110101.html
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/69639-wlc-failover.html
