t.matsudo
My report[1] tells you the experimental results of the performance of Cisco ClientLink supported on Cisco Aironet access points. You can remember the great performance of ClientLink forever.
I have learned that new access points for IEEE802.11ax are Cisco Catalyst 9100 access points. I have also learned that only transmit beamforming specified by 11ax is in the new access points and that Cisco ClientLink is no longer supported on them.
Since we and our many customers have been helped very much by Cisco ClientLink, I would like to express my appreciation to Cisco ClientLink in the report.
[1]My report has been opened to the public at <https://www.netone.co.jp/knowledge-center/blog-column/matsudo20200320/> since Mar.20, 2020.
4 Comments
Martin L
interesting; thanks for sharing!
t.matsudo
Hi, Martin L (Rising star) ,
Thank you very much for your comment and giving 5 stars of helpful !
OddievenInc
Learnt something new. Great stuff!
t.matsudo
Hi, OddievenInc,
French webcast-routing
