ISE 2.1 802.1X and MAC filtering
samuel.cardenas
we have an SSID with more or less this configuration:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/201044-802-1x-authentication-with-PEAP-ISE-2-1.html
802.1X validated with an Identity Group user (Internal users)
We want to permit access only a devices that are included in a Identity group endpoint (a MAC address list).
How can add a policy to validate this point in my actual configuration?
Thanks in advance.
Samuel
I found the solution:
In the controler SSID select MAC filtering.
authentication rules:
1- 802.1x and use:AD
2-MAB and use: indentity endpoint
in authorization:
1 rule: Identity: AD and 802.1x
2 rule: Identity: Identity group endpoint and condition MAB
result both the same.
the first process, as I select the MAC filtering in the controller, are the rules with MAB, and later use the 802.1x.
if one of them fails. can't access!! :)
thanks!! :)
6 Replies 6
Arne Bier
Interesting question
There is no easy way to do this as far as I know.
if you had the users in AD, then you could perhaps have an AD user object (e.g. macAddr)  that contained the MAC address, and then in your Authorization Policy you could try an AND rule that looks something like:
MY_AD macAddr EQUALS Radius Calling-Station-Id
No idea if that will work.
in authorization:
thanks!! :)
Did you set this up in your lab? How does the controller do MAB and 802.1X on the same wlan profile? I didn’t know it was possible to mix the two auth methods.
yes, not in lab, in production. is a new SSID.
the SSID is a WPA2 entreprise, so is 802.1x, but if you select MAC Filtering in the SSID (security) the controller first send the authentication/authorization for the MAC, and later the 802.1x.
Is working fine.
I just tried this on our Cisco virtual controller (8.5.131.0) and I had to turn off the Radius NAC in the WLAN in order for MAB to be enabled at the same time.   And yes this is pretty amazing - thanks for pointing this out.  I am wondering what this Radius NAC setting does ...  ? Because we just blindly set this according to all the docs ... now 802.1X and MAB work just fine without it.  I think I am about to learn something new ... do you have any clues what this is for?
this works great, can you explain the work process on the ISE/WLC?
eg user enter username/password on laptop.
un/pw info + wifi mac pass to WLC -> ISE
ISE authencticate first on authentication rule1? then rule2? then authoriation rule 1 rule2?
would you please explain on above?
thanks
