Management IP for Mobility Express
HamzaD
Frequent Visitor
Frequent Visitor
I want to set up a Cisco Aironet AIR-AP1832I as a mobility express.
I configured the switchport as the following:
interface GigabitEthernet1/0/38
 switchport trunk native vlan 120
 switchport trunk allowed vlan 1,120,121
 switchport mode trunk
end
I configured the AP via the initial configuration wizard and I set a Management IP address on vlan 120: 192.168.120.150/24.
The AP restarted but I can not access the user interface with that management IP nor ping it, the status LED keeps blinking RED and there is no SSID broadcasting !
Any suggestions would be appreciated.
Hamza,
Sandeep Choudhary
paste the output of thsese command from ap console:
sh interface detail management
sh version
Dont forget to rate helpful posts
sh version
Here is the outputs:
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 70:6b:b9:96:64:60
IP Address....................................... 192.168.120.150
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.120.254
IP Address Type.................................. Static
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
Link Local IPv6 Address.......................... fe80::726b:b9ff:fe96:6460/64
STATE ........................................... NONE
Primary IPv6 Address............................. ::/128
Primary IPv6 Gateway............................. ::
Primary IPv6 Gateway Mac Address................. 00:00:00:00:00:00
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Physical Port.................................... 1
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. Unconfigured
Secondary DHCP Server............................ Unconfigured
--More-- or (q)uit
DHCP Option 82................................... Disabled
DHCP Option 82 bridge mode insertion............. Disabled
IPv4 ACL......................................... Unconfigured
IPv6 ACL......................................... Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
VERSION:
AP706B.B996.6478 uptime is 0 days, 0 hours, 51 minutes
Last reload time   : Tue Jun 30 09:33:54 UTC 2020
Last reload reason : unknown
cisco AIR-AP1832I-E-K9 ARMv7 Processor rev 0 (v7l) with 997268/474592K bytes of memory.
Processor board ID KWC21480DKW
AP Running Image     : 8.5.140.0
Primary Boot Image   : 8.5.140.0
Backup Boot Image    : 8.2.151.0
AP Image type    : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : f6d58b5e05c762162e07fe70e0671647
NSS FW version : NSS.AK.C.CS-3-fix2
Base ethernet MAC Address            : 70:6B:B9:96:64:78
Part Number                          : 0-0000-00
PCA Assembly Number                  : 074-104694-01
PCA Revision Number                  : 01
PCB Serial Number                    : KWC21480DKW
Top Assembly Part Number             : 074-104694-01
Top Assembly Serial Number           : KWC21480DKW
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1832I-E-K9
sh version
--More-- or (q)uit
VERSION:
2 802.11 Radios
