ā10-24-2018 06:56 AM - edited ā07-05-2021 09:22 AM
I was deployed ISE Guest Access Service with Cisco ISE 2.4.0.357(ISE-VM-K9) and Cisco WLC 8.3.143.0(AIR-CTVM-K9), I want to limit client bandwidth per user in this service,So i used authorization profiles via Cisco ISE, i set advanced attributes as below, when client connect to Wireless Network this attributes passed to the WLC but doesn't work correctly (it means that QoS just applied on Up Stream )
Some idea.. someone can help me.
Thanks in advance
Aire-Real-Time-Bandwidth-Average-UpStream-Contract = 4000
Aire-Data-Bandwidth-Average-DownStream-Contract = 4000
Aire-Data-Bandwidth-Burst-UpStream-Contract = 4000
Aire-Real-Time-Bandwidth-Burst-DownStream-Contract = 4000
Aire-Real-Time-Bandwidth-Average-DownStream-Contract = 4000
Aire-Real-Time-Bandwidth-Burst-UpStream-Contract = 4000
Aire-Data-Bandwidth-Average-UpStream-Contract = 4000
Aire-Data-Bandwidth-Burst-DownStream-Contract = 4000
Solved! Go to Solution.
ā11-14-2018 12:45 PM
I'm supposing that you are using a Virtual WLC.
In this case if SSID is configured in central switch you can apply traffic shaping policy only in upstream and not in downstream.
This feature is not supported on vWLC as you can read from release note.
ā10-24-2018 07:08 AM
Look at the thread should able to help to resolve the issue :
ā10-29-2018 04:34 AM
i visited this page Before, it didn't work
if someone have success to use this Attributes please help me!
ā10-29-2018 02:33 PM
explain more ? what is not working ?
ā11-03-2018 01:45 AM
in Cisco ISE>Work Center>Guest Access>Policy Elements>Authorization Profile i Create Profile and for Limiting client bandwidth I set parameterers For Airespace Attributes, after Client connected to Network with this Authorization Profile the Upload bandwidth is limited But Download bandwidth is not limited.
how could i limit Client bandwidth with Authorization Profile(Advanced Attributes Settings)?
