WLC 5760 operation state down
TimurKaneev
Hi all.
I have 2 WLC 5760 (version 3.6) in stack and 20 APs .
All APs registered on WLC but  operation state in both radio is DOWN .
APs connected on different switches.
What can it be ?
Yes, if it is disabled due to PoE then you need to correct that. If AP model are newer one (2700/3700) then try to power them from a POE+ switch
If you have a test AP then you can watch the console output while powering/booting. That will tells if AP radio goes down with reason.
Rasika
**** Pls rate all useful responses ****
Have you configured the correct country code on your 5760 ?  If you check "show wireless country configured" & see the correct configuration done.
Rasika
Hi Rasika.
County code on wlc same as on APs
wlc-1#show wireless country configured
 Configured Country.............................: RU  - Russian Federation
 Configured Country Codes
        RU  - Russian Federation : 802.11a Indoor,Outdoor/ 802.11b / 802.11g
wlc-1#show ap status
AP Name                             Status     Mode              Country
APb838.61f3.2ed9                    Enabled    Local             RU
APb838.61f3.2f1b                    Enabled    Local             RU
AP18e7.28bd.4ef1                    Enabled    Local             RU
I think problem in PoE , cause APs conect to old 6509 with CatOS, but output comand show port powerinline  show that all good and 15.4 W go to port.
 8/73  auto   on       15400   14607   13000             cisco+ieee  class 3
 8/74  auto   on       15400   14607   13000             cisco+ieee  class 4
 8/75  auto   on       15400   14607   13000             cisco+ieee  class 3
 8/76  auto   on       15400   14607   13000             cisco+ieee  class 3
 8/77  auto   on       15400   14607   13000             cisco+ieee  class 3
In the output "show tech"  from the ap a found this message
Radio disabled due to PoE
Rasika
I have 2 types of APs - 2600 and 3600.
Yes , just now connect APs to new 3850 switch and all APs go to UP .
Thanks for all .
