01-19-2007 07:14 AM - edited 07-03-2021 01:30 PM
hi
i wanted to increase the security on my 1121G accesspoint by enabling wpa2 with aes encryption. i set this up in a test environment and i configured my wireless client to connect, my wireless client (ibm thinkpad t42p with 11a/b/g Wireless LAN Mini PCI Adapter II has the ability to either select WPA or WPA2 and whether you use TKIP or AES. i selected WPA2 and AES enter the encryption key which i had entered on the AP and i connected,
i change the settings on the client to WPA and TKIP and entered the same encryption key and i managed to connect as well, which puzzles me, when i enter an incorrect encryption key it won't associate.
is this normal behaviour or do you think i have configured something incorrectly on the 1121G AP?
i have attached my config and have removed some personal data.
many thanks
rogier
01-22-2007 10:52 PM
entering an incorrect encryption key will cause you to not associate - this is correct.
Is that your question or did I miss something?
01-23-2007 01:45 AM
with the config i have i seem to be able to login using either tkip or aes, but i don't think i have got mixed mode configured on the AP so it should only accept WPA2-AES encryption but it also accepts TKIP making me believe something is configured incorrectly.
should i change anything in the config on the AP to only allow WPA2-AES encryption?
many thanks
rogier
01-23-2007 11:37 AM
Well AES and WPA2 or WPA and TKIP, either way you still had the correct key, so apparently you are allowing both.
Can you post the AP config?
01-23-2007 11:40 AM
Damn, blonde moment...sorry.
What do you have guest mode for? Get rid of that see what happens
