An AP500 with internal antennas?
richroller
Is there any chance that an AP500 might be developed with internal antennas?
I have at least one deployment where the AP541N might have been seriously considered, except for its external antennas, which for that site are too vulnerable... of being moved, tampered, etc.
So in that case the AP1142 with its internal antennas and smaller footprint, is a better fit.  But the 1142 is a lot more expensive, doesn't do clustering, etc.
If a new model of AP500 were developed to fit into the casing of an AP1140 that would be, for some customers, quite an enticing product!
But I'm not holding my breath... it seems Cisco made a decision to use only external antennas with these.
-Rich
wichilds
Level 4
Level 4
Rich,
Thank you for your feedback, its great to hear from end-users about how we can make our product lines fit your needs better. These boards are HIGHLY visible to Cisco. Therefore, I'm sure your concerns will be heard and addressed accordingly.
Bill
I have also queried the PM for this product.  Stay tuned
