10-03-2013 05:42 AM
one of my ap541n access points behaves strangly.
It returns out of the blue to the default config.
This is what the log tells me:
Oct 3 05:36:10 | err | mDNSResponder | mDNSPlatformRawTime went backwards by 2138801570 ticks; setting correction factor to 862212335 |
Dec 31 16:00:26 | info | syslog | managed_ap.c:399:map_init_sub_components - Created the MAP Switch Comm Control Block |
Dec 31 16:00:26 | info | syslog | managed_ap.c:1518:map_vpd_init - Done parsing VPD. Size = 0 |
Dec 31 16:00:24 | info | syslog | managed_ap.c:1486:map_vpd_init - Default Configuration is applied to the running config |
Dec 31 16:00:21 | notice | mini_httpd-ssl[411] | mini_httpd/1.19 19dec2003 starting on AP541N-A-K9, port 80 |
Dec 31 16:00:21 | warn | mini_httpd-ssl[411] | started as root without requesting chroot(), warning only |
Dec 31 16:00:20 | notice | mini_httpd-ssl[412] | mini_httpd/1.19 19dec2003 starting on AP541N-A-K9, port 443 |
Dec 31 16:00:20 | warn | mini_httpd-ssl[412] | started as root without requesting chroot(), warning only |
Any idea what can cause this issue?
I have to add that once rebooted into default config, the webinterface responds really slow.
John
10-03-2013 05:58 AM
argh, whatever I do... it keeps rebooting into default config.
I guess this is a harware issue.
J
10-04-2013 05:16 AM
Hardware issue is ruled out. I replaced the access point with another one.
Same behaviour.
I get the idea that the problem starts when joining the cluster.
10-07-2013 10:18 AM
For anyone who experiences the same problem => CHECK THE MAX PoE OUTPUT OF PoE SWITCH!!
When you are on the limit of the switch PoE power output you may see that the switch seems to receive enough voltage becaus it starts when plugin in the utp cable. well, 7.2V is not the required 8V!! T
That triggers the configuration reset on the access point.
John
