Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi folksI bought 3 WAP321s with the intention of creating a fairly wide network in a large building where I can't easily add wiring. Access was to be via a captive portal where I would create logins for all of the users. However since I have bought...
Using Cisco WAP4410N Wireless Access Point (WAP4410N-E V01) in office premises, which get’s rebooting automatically.It’s using latest Firmware 2.0.6.1 & having 2 SSID’s broadcasting. Both are getting client IP's from same VLAN with different auth...
Hi,In a bit of a pickle and not sure which way to turn as I think I have exhausted all possibilities.We currently have 2 Cisco WAP4410n wireless access points running within our network. They are both on version 2.0.4.2 firmware and both on a static...
Best practices include : passwords must contain A..Za..z1..9 + special characters (+=-&;! etc ) Using local database or Radius, same filter in WAP321 (Firmware Version: 1.0.4.2 ) :special characters are forbidden by Captive portal ...
Hello,I have a problem in connetion between the access point and Apple iPhone and iPad.Firmware version 2.0.6.1Try with WPA-Personal (both AES and TKIP) and WPA2-Personal encryption too.Appliance works in Access Point mode.Anybody has had the problem...
I change the duplex from Auto/Auto to Full/1000 via the attached screenshot setting in the web access console. Now the AP will not respond and allow items to connect to the AP. I can no longer access it via the URL or ping it. Any ideas on how to get...
Hello,one of my ap541n access points behaves strangly.It returns out of the blue to the default config.This is what the log tells me:Oct 3 05:36:10 err mDNSResponder mDNSPlatformRawTime went backwards by 2138801570 ticks; setting correction factor t...
I have 2 WAP321's set up in Single Point. I have 20MB downspeed available. No matter what i seem to change, i cant get more than 2-3MB downspeed. I have tried it on multiple gateways, multiple locations, and on multiple devices. It is something w...
Hi allEquipment:ASA 55052x gs 200-082x wap321Is there a possibility, to bridge 2 VLAN between one and another side with two WAP 321 and use the AP's also as WDS Bridge to extend the Wireless Network? I need to extend the Range of the WLAN but also wa...
Hello all,A while ago I purchased a Cisco WAP121 for dedicated use by my two 802.11n laptops only, hoping to enjoy maximum speed for transferring files etc. All other devices use an older 802.11b/g access point. I live in a remote area so there are n...
When trying to upload rootfs.bin file found in .tar archive, progress bar moves to about 70%, then process is stopped with the"Firmware upgrade has failed. Please ensure that valid entries were specified in the required fields"message.Can anybody hel...
hi,I've been trying to get a Cisco WAP321 working with Radius authentication with a Windows 2008R2 Active Diretory server and I cna't make it work.The etries in the WAP log are very vague:Sep 25 2012 11:57:52 info hostapd[6247] wlan0: IEEE 802.11 ...
Hello,I was discussing the WAP321's roaming in this thread https://supportforums.cisco.com/thread/2192532?tstart=0 but wanted to move the discussion to wether I should use 2.4ghz or 5ghz.It's a real shame that this device does not support dual band b...
I want to create one more SSID (for guest use) in WAP321 AP. Is it possible to perform such setup with non-cisco switch and firewall. Please advise. Thanks !
