WAP131 error messages in log file /WANCfg.xml / WANIPCn.xml not found, responding ERROR 404
steverack
Hello There, On a WAP131, I am seeing below entries in the log-file, which start being populated roughly 6 hours after a power cycle. Firmware 1.0.1.4 (latest version) Time Stamp Severity Service Description Mar 29,2016 12:00:28 notice miniupnpd[1160] /WANCfg.xml not found, responding ERROR 404 Mar 29,2016 12:00:28 notice miniupnpd[1160] /WANIPCn.xml not found, responding ERROR 404 Mar 29,2016 11:59:34 notice miniupnpd[1160] /WANCfg.xml not found, responding ERROR 404 Mar 29,2016 11:59:34 notice miniupnpd[1160] /WANIPCn.xml not found, responding ERROR 404 Mar 29,2016 11:58:39 notice miniupnpd[1160] /WANCfg.xml not found, responding ERROR 404 Mar 29,2016 11:58:39 notice miniupnpd[1160] /WANIPCn.xml not found, responding ERROR 404 Mar 29,2016 11:57:47 notice miniupnpd[1160] /WANCfg.xml not found, responding ERROR 404 Mar 29,2016 11:57:47 notice miniupnpd[1160] /WANIPCn.xml not found, responding ERROR 404 Mar 29,2016 11:56:53 notice miniupnpd[1160] /WANCfg.xml not found, responding ERROR 404 ... The log file is full with these entries, The WAP 131 seems to be working fine, only that several times a day the AP seems to be "blackholing". The wireless connection stays up but no data is travelling through. After 1 minute or so, it works again. Tested with Windows 10 laptops, Windows 8 phones, iPads and iPhones, with same unsatisfying result. The AP is configured with 2 Vlans and connecting to an SG300-28 switch. I am not sure if both issues are related or separate. Does anyone have seen these entries and have a solution? Thanks
6 Replies 6
steverack
After reseting to factory defaults and manually re-applying the configuration, my WAP131 has been stable for 12 days now, which is good progress.
Still I am seeing above entries added the log-file every minute though.
Is anyone else seeing the same entries on their WAP131? I wonder what it means and if my device is somehow broken.
I see your same entry i my log...
i think is device linux based and is a notice from a service not disable by gui.
This is a "Not Found' message. I'll have to investigate what's not being found. What the status of your devices, are they still functioning?
Device non work fine...
We have some problem with ipad/iphone who disconect end no riconnect.(reason unknow there are similar post in the forum for other apn model with same issiu).
Apn 5ghz have problem (disappear) and only whit a reboot it return up and running.
Entry level cisco apn are non a good idea..
Thanks for asking Glenn.
My AP131 is still showing above error messages.
The other day I upgraded to firmware 1.0.2.2 and was hoping to get rid of above error messages. 4 days after reboot, they have come back.
At least the "blackholing" issue hasn't come back since last reboot. I am keeping an eye on the device.
I wouldn't care much about above entries, if there wasn't this "blackholing" issue, as these may be interrelated.
steverack
Since firmware version 1.0.2.8, the 'responding error 404' in the logs seems to be gone for good.
Also the 'blackholing issue' hasn't come back since.
With 1.0.2.2 I could get rid of the 'blackholing issue' by disabling 'green ethernet' and 'bonjour'. With the new 1.0.2.8 I have re-enabled 'bonjour' and am yet to disable 'green ethernet' and see if it comes back.
Update 12th January 2017
After roughly 1 week the 'responding error 404' in the logs has come back :-/
