02-07-2023 04:38 AM
What is the replacement model access point of Cisco AIR-AP1832I-D-K9?
at my office has this model AP. but we want to replace the AP. what is the cost effective replacement model of this AP?
02-07-2023 05:59 AM
is this is the only AP you are using? is this AP joined to controller or standalone? for 1830 series new replacement is 9115AX series. (https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/datasheet-c78-741988.html) but make sure to match with other APs in network (if any) or controller compatibility (if any) in your network.
02-09-2023 12:26 AM
Hi, here we are using some AP which is connected with WLC. but this model is older and almost unavailable in the market, so wanted to know the replacement of 1830 series which is compatible and supported with WLC.
