Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi!I have Cisco Business 240ac Access PointMy question is can I connect AP with different switches or it must be available as special switches?(For Poe Port I Can Fix Business Poe Injector)
Hello,Does the 150AX support WPA3-OWE (Enhanced Open)? It's essentially an 9105AXI (ap1g8) with a modified version of EWC, correct? The 9105AXI does support OWE, but I can't find anything about the 150AX.We currently use 1815i APs with Mobility Expre...
I bought 2 Cisco WAP581 wireless APs. I am having a problem with the wireless going offline after a day or two. My Windows 10 laptop comes up and says there is no internet access after 24 hours. From the wireless laptop I cannot ping the WAP581 from...
my mesh network shut itself off yesterday after two years of pretty much trouble free use. All of my access points now blink red/yellow/green and i cannot log onto the primary access point. Undoubtedly some piece of firmware is out of date or faile...
Buenos días. Tengo el router RV260W Firmware 1.0.01.10. Tengo el problema que de vez en cuando se desactiva el WIFI. Lo tengo configurado solamente en el radio 2.4G. Por ahí he leído que tengo que desactivar WMM pero persiste el problema. Lo reinicié...
The title says it all. We have purchased a pack of three Cisco 240AC wireless access points model: CBW240AC. I have them all updated to the latest software (10.7.1.0) and the group of them work together with two SSID's that we have configured for ...
Hello evrey one!Can I connect Cisco Business 240AC Access Point with any others ( not cisco till example) switches or i have to connect with special Cisco Switch. Thanks
This 240AC access point fails with a blinking red led after I configure it.I factory reset & it brings up the config UI from the wireless side, but after config it reboots to a blinking red led again.The only time I see my custom ssid is in the five ...
Hi there,
got the WAP371-A-K9 about a year ago and expended the network to 3 more WAP371-E-K9 (couldnt find anywhere the A-k9....)
the representative confirmed that they can be clustered together. but so far i can cluster the 3 "E"s without the A one...
What is the replacement model access point of Cisco AIR-AP1832I-D-K9? at my office has this model AP. but we want to replace the AP. what is the cost effective replacement model of this AP?
I have the cisco buniness 140AC access point and would like to use the Cisco Business Dashboard to connect them all. I would like to know how to get my Cisco Business Dashboard setup and add AP
Hi,Thinking about buying a couple of CBW150AX and/or CBW151AXM Access Points but was wondering how configurable the backhaul is. Has anyone tried them or specifically, has anyone tried configuring a wired backhaul for multiple CBW150AX units.This wou...
