cisco wap4410n
Fabio Martins
hello there, i recently bought a cisco wap4410n for my home lab, i configure it, and it was running perfect
there i something that i noticed: when i created the 3rd ssid, computers couldnt ping each other
example: ssid 1 - pc1 can ping pc2
               ssid 2 - pc1 can ping pc2
               ssid 3 - pc1 can't ping pc2, both pcs can ping the default gateway (10.1.70.2), but they cant ping each other,
and if pc1 is in the ssid 1 and pc2 is in the ssid 3 they can both ping each other, but if i put both in the ssid 3 they wont ping each other
can anyone help me?
bst rgrds
Fabio Martins
cchamorr
Level 5
Level 5
This sounds like you enabled the wireless isolation feature on SSID 3.
From the admin guide:
Security
The Wireless > Security page displays the wireless security settings of the access point. To configure the wireless security settings of the access point, follow these steps:
Click Wireless > Security.
To configure wireless isolation between SSIDs:
a. From the Select SSID drop-down menu select an SSID.
b. To isolate wireless clients from each other,click Enabled. Otherwise, click Disabled.
To prevent wireless computers associated to the same SSID from seeing and transferring files between each other, in the Wireless Isolation (within SSID) field, click Enabled.
I hope this helps. Please let us know
cchamorr
Level 5
Level 5
Security
hello,
thanks for your advice, it helped me a lot, i forgot to disable the wireless isolation when i created the ssid 3, now I'm able to ping and communicate with other pc's in the same ssid
thanks a lot
bst rgrds
Fabio Martins
I'm glad to hear that it worked for you.
Please don't forget to mark an answer as correct if it was helpful tp you so that others can benefit from it.
Thank you.
