Combine WAP321 with WAP561?
Michiel Beenen
Level 3
Level 3
Hello all,
Is it possible to use the 321 and 561 wifi points together into this new Single point setup?
lariasqu
Hi Michiel, thank you for using our forum, my name is Luis I am part of the Small business Support community. If you are trying to connect your WAP561 with WAP321 through WDS, following the admin guide it is not possible due WDS only works with Cisco WAP121 and Cisco WAP321 devices, this is one of few guidelines you are able to find in the admin guide, please check this info in the link below, page 90.
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
Hello Mr. Breenen,
My collegue is correct WAP121 and WAP321 will only do WDS between themselves.
WAP121 ----WDS---- WAP121
WAP321 ----WDS---- WAP321
But you can also do
WAP551 ----WDS---- WAP551
WAP561 ----WDS---- WAP561
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
Yeah well, why cant they make 321 and 561 work together through single point setup? We have 4 of the 321's and wanted to put 2 extra WIFI points in our building and thought it would be best to do that with the 561, but if they dont co-op like that I guess we have to go for more 321's.
