Configuring Guest VLAN on AP541N and UC560
Kelli Lowe
I have a AP541N connected to a UC560.  We are currently configured for Wireless Voice and Data.  We have added a Guest VLAN, but don't see where in CCA to secure the VLAN from accessing the other other two default VLANs.  Any help would be appreciated.
Additional Info:
AP541N-K9-1.7(2)
UC560  15.0(1)XA2, RELEASE SOFTWARE (fc2)
CCA 3.0
tsawchuk
https://supportforums.cisco.com/docs/DOC-14855
We are experincing the exact same problem in our lab.
There is no way with CCA that the VLANs can be secured. You have to use CLI, howerver once you choose to use CLI for configuration CCA may no longer be used.
Hope this helps.
Terry
