Error AP POWER
lisavbedt
l getting error on ap is flashing red green and blue and my switch is cisco small business SF300-POE And no wifi this ap is covert to me newest version sill flashing red green blue
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2800-series-access-points/datasheet-c78-736497.html#Productspecifications
Input power requirements
●  802.3at PoE+, Cisco Universal PoE (Cisco UPOE ®)
●  802.3at power injector (AIR-PWRINJ6=)
Whether or not your SF300 switch supports 802.3at depends on the exact model number of the switch. Refer to the Power over Ethernet (PoE) table at https://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html to see whether your switch supports it or not.  If not then you will need a power injector or switch which does support 802.3at (POE+).
12 Replies 12
marce1000
     - That means that the AP is getting insufficient power ,
 M.
How do l fix it ? Do l need switch with poe+??
 - Start by looking at the datasheet of the particular AP model and look for powering requirements, then compare to switch capabilities , or find other switch model (e.g.) ; or use power adapter
 M.
Rich R
What model of AP?
What version of software?
Do you have CDP or LLDP enabled on the switch port?
  • no l think not and ap is update to newest version ME
  • no l think not
    CDP or LLDP is required for POE+ to work correctly.
  • and ap is update to newest version ME
    So you confirm it is running 8.10.190.0?
Good Reading l orderd new switch Cisco with poe+ when arrived l hope its works?
Yes ap running newest version
Al model is airap2802i-b-k9
problem is sloved its was switch new switch is arrived with poe+ and worked normal en showing my wifi thanks everyone
