01-21-2013 11:49 AM
Hi, I need enable WPS function on WAP4410N. Help says that this is possible with CLI command #set wps enable. But how I can connect to WAP4410N with CLI? Thanks for any suggestions.
01-21-2013 11:58 AM
Hi Jan, you may telnet the WAP4410N. However, the CLI is not a supported configuration method.
-Tom Please mark answered for helpful posts
Log in to Community
