How to access ssh on Cisco Business CBW150AX ?
EasyZone
Dear all
I have a new cbw150ax-s unk access point.
I have set a captive portal and test AAA authen with external radius.
All work fine but there is no accounting send to my radius server.
So I need to access ssh to use terminal and enable radius accounting.
I enable SSHv2 on then I ssh to AP ip address.
I got error :
easyzone@easyzone-IdeaPad-5-15ITL05:~$ ssh 192.168.88.251 -l ssh
ssh@192.168.88.251: Permission denied (publickey,keyboard-interactive).
It seems cbw150ax needs a publickey instead of use normal username and password.
But there is no option in web management to generate a ssh public key.
I saw a serial port
 But which cable I can connect to this port.
Please advice me.
Thank you in advance
Chuan chudabut
https://www.cloud-hotspot.com
2 Accepted Solutions
   - No , it's just means that SSH on the device is not available for customer use ,
 M.
EasyZone
I have found how to enable radius accounting for captive portal without access ssh.
Method is below
1. Go to Advanced > Primary AP Tools > Configuration Management
2. Download config.txt from this menu
3. edit config.txt (before edit the file you need to set a captive portal and test AAA authen with external radius first).
Find lines
config wlan radius_server acct interim-update disable 3600
config wlan radius_server acct disable 5
change them  to
config wlan radius_server acct interim-update enable 3600
config wlan radius_server acct enable 5
4. save and upload config.txt to ap with the same menu.
5. wait for ap reboot them check it.
12 Replies 12
marce1000
  - Could you hoover or press on the little blue question mark  mark near sshv2 access ; you may get more info's as to how setup SSH  ,
 M.
Thank you so much for your reply and I sorry for my late reply.
The picture below is message info on little blue question mark.
It is a message. It provides nothing about how to setup.
Please advice me ....
          >...It provides nothing about how to setup.
       It does : SSH is for Engineering debug only ,
 M.
This message means normal user can not access on ssh because we don't have a public key and there is no option to create a public key for ssh.
Is it right?
 M.
Thank you so much.
So I need to looking for a console serial connection port.
 - Ref : https://www.cisco.com/c/en/us/support/docs/smb/wireless/CBW-AX/kmgmt3378-get-to-know-150ax-151axm.html
             >..      Console Port (For Tech Support Only)
                             Seems like a dead lock...
 M.
My goal is to enable radius accouting for captive portal.
I wonder why EAP 802.1x authentication with external radius. a radius accouting function is enable by default.
But captive portal with external radius, a radius accouting function is not enable by default.
I try to enable it.
Do I need to submit on CBW feature request?
 - Note sure  if it can be done with captive portal  , check this document :
 https://www.cisco.com/c/en/us/td/docs/wireless/access_point/csbap/CBW_WiFi_6/Admin_Guide/b_cisco_business_wifi_6_admin_guide/m_4_wireless_settings.html
                  Look for Radius Accounting with Find in the browser ,
 M,
Thank you.
But there is no radius accounting from captive portal sends to my radius server.
 - To me it looks more  that you will have to use higher end models and or APs out of the Small Business oriented market(s) ;
you may also ask Cisco through https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
 M.
EasyZone
Method is below
Find lines
change them  to
