Cisco 150AX doesn't show Nearest AP. Even though they have joined
DeltaEchoV
As attached in the above screenshot none of the client devices show neighboring AP in Network Summary. Is this expected behavior?
FYI, the client can see all the APs but the Cisco 150AX AP is not reporting the same.
Is there something I am missing?
7 Replies 7
marce1000
       - Make sure the 150 AX problem is running  the latest firmware ,
 M.
All APs are running the latest version. Can someone from cisco tech support help me with this?
   - This forum is used by Cisco customers , you won't get any replies from them here :
      For official supporthttps://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
 M.
DeltaEchoV
Any one else facing above mentioned issue or is it just me?
Aironet IE
Advertise AP name
These two options need to check if you need to see AP name
MHM
Rich R
To be honest I'm not sure what should be in there - where is the AP supposed to be getting that information from?
In a controller based environment the WLC/APs are aware of the neighbouring APs and can use that info for 802.11k reports to the client: https://blogs.cisco.com/networking/why-the-802-11k-and-neighbor-report-are-important
I suspect this may just be a hangover from a GUI screen which has been borrowed from the controller code but not used on these APs.  https://www.cisco.com/c/en/us/td/docs/wireless/access_point/csbap/CBW_WiFi_6/Admin_Guide/b_cisco_business_wifi_6_admin_guide/m_8_appendix_a_supporting_topics.html suggests it is used for extenders not clients on these products.
https://community.cisco.com/t5/wireless/nearest-aps-are-not-the-actual-nearest-aps/td-p/3777385 explains how it normally works on a controller.
DeltaEchoV
AFAIK RRM means 802.11v and 802.11k support. Even the client shows AP has 802.11k and 802.11v support. These APs have integrated/embedded controllers (or whatever it is called). It should show the data.
PS: just for fun I went through techsupport bundle and I can see 2.4 neighbors but not 5ghz neighbors.
RRM Neighbors:
MAC Addr RSSI Srv.Chan
<MAC address> -68 11
<MAC address> -53 1
