I would like suggestions on a cost effective point to point wireless bridge setup with approximately 300Mbps throughput.
Keith Jones
I need to design a point to point wireless setup for a client and the locations are about 1000 feet apart.  I was contemplating using 2 X AP541n access points with MIMO antennas, but can't really find any documentation on if this would work, or even what the effective throughput of an AP541n in WDS is.
I am open to suggestions of solutions that people have come up with.  I also am interested in hearing how you tested the throughput of the solution, and what type of antenna you used.  Did you use a MIMO antenna with 3 antenna connectors on it, or did you use 3 individual antennas?
Thanks!
jeffrrod
Level 4
Level 4
Dear Keith,
Thank you for reaching the Small Business Support Community.
Based on the AP541 datasheet;
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10492/data_sheet_c78-566239.html
I see no way to accomplish your needs (300Mbps throughput through out a 1,000ft WDS setup) with this AP541 or any other of the Small Business access points.  I suggest you to look at the enterprise products and inquire about it on their community support forum;
https://supportforums.cisco.com/community/netpro/wireless-mobility
Please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
