09-02-2013 09:22 AM
Laptop wifi connection(WAP321) Works! for the file server and internet services.
However printing to specific printer(wired connected) on the network is failing. Unable to connect.
Is there a 'port' configuation that I might have overlooked for the WAP321. Suspecting this may be blocking trafic.
09-06-2013 08:28 AM
Hi Harvey,
Can you please provide your configuration summary to better understand your issue.
Phanikrishna
09-12-2013 01:21 AM
Hello Harvey,
Are you able to ping this printer? Also is the printer properties on the computer set to go to the ip address of the printer? What ip address is configured on your printer as well.
Pretty much out of the box this device would not be blocking any traffic to the printer if that is what you're suspecting.
Hope that helps,
Clayton Sill
09-12-2013 04:11 AM
Was able to ping printer ok.
So I've Reset WAP321. Installed latest firmware. Now wifi MacBook laptops can send print jobs. Think i'm good for now.
