Management model of WAP121
t.takemoto
I'd like to know if WAP121 can be centrally managed by WLC, such as CT5508.
If WAP121 cannot be centrally managed by WLC, is there any way to minimize operation work to manage WAP121?
lariasqu
Hi t.takemoto, thank you for using our forum, my name is Luis I am part of the Small business Support community. As far I know there is not any supported software from Cisco for Small Business devices.
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
There is a feature that comes with the WAP100 and WAP300 series Access Points. It is called Single Point Setup.
You can read about it in the Admin Guide located here:
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf
With the WAP 100 Series you can cluster up to 4 AP's together.
Please let me know if you have any questions.
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
*Please rate the Post so other will know when an answer has been found.
naarjuna
Hi t.takemoto,
You can refer to this article Single Point Setup Configuration on WAP121 and WAP321 Access Point. It helps you to configure the Single Point Setup on the WAP device.
