N9K-C9236C Connectivity
sachinc01
Hi Team,
I have above switch N9K-C9236C and my end NIC card has 200GB card i want to do the connectivity between Switch to server to using splitter cable 2port 100Gb + 100GB switch side and next hope will be my NIC it has 200GB
So which QSFP Module and Splitter cable do i need please guide me and share compatible matrix it will support to NIC or not.
balaji.bandi
my end NIC card has 200MBPS card
200MB  is this correct ? this is non-standard.
Look at the N9K Model datasheet :
Possibilities :
The Cisco Nexus 9236C Switch (Figure 5) is a 1RU switch that supports 7.2 Tbps of bandwidth and over 5.3 bpps across 36 100-Gbps QSFP28 ports. Each of the ports on the 9236C can be individually configured into 1x100Gbps, 1 x 40 Gbps, 4 x 10/25 Gbps, 2 x 50 Gbps or 1 x 1/10 Gbps using QSA adapter. It provides industry’s best density and flexibility needed for data center spine or aggregation connectivity, in a compact form factor.
Cisco Nexus 9200 platform switches’ characteristics
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-735989.html
BB
Sir, Sorry Its mistake the NIC is 200GBPS speed can i use 100GB  X 100GB  Splitter cable in switch side, (Switch has 100GB per port can i use both port through splitter cable,Please see the attached diagram if it will be possible please suggest require module and splitter cable.
aatifriaz67
You can use a QSFP28 100Gb module and a QSFP28 to 2x100Gb splitter cable on the switch side. Ensure the splitter cable is compatible with both your N9K-C9236C switch, and the 200Gb NIC on your server.
