07-22-2015 01:35 PM
I recently got an 1602i-K9 access point and I can not enter a configuration part :
* I do not have the static address management so I cann't use web browser
* When I plug my 1602 AP on a dhcp server, the bvi interface takes an IP address, I cann't enter telnet and I cann't ping this IP adress
* and when I use the console mode,I can acces the devise, get the enable mode but the command configure terminal does not work
Any help regarding the configuration of this device please ??
07-23-2015 01:16 AM
Always in the same subject,
Show version result : Version 15.2(4)JA1
Commande Configure terminal doesn't work, may I upgrade device ?
Thank you
08-06-2015 12:58 AM
Could you please let us know if you would use it as Controller Based or Standalone Mode?
08-10-2015 02:04 PM
I am trying to use 1602i as standalone.
08-11-2015 04:31 AM
If you have it on Lightweight Image, follow the instructions to convert it to Standalone mode:
Lightweight to Autonomous Conversion
Once done, please refer to the following guide:
Cisco IOS Configuration Guide for Autonomous Aironet Access Points
08-11-2015 05:08 AM
I don't have a controller. The AP i Have is CAP not a SAP
08-11-2015 05:37 AM
Yes, you have Controller- based Image on it (CAP).
You'd have to change it to Standalone Image.
Please refer to the links, I've shared earlier.
Hope that helps.
