Question: Cisco business 240AC max number of Access Point
mxia
I have purchased 30 cisco business 240AC devices, but I review the datasheet, it shows max number of Access point is 50, recommended up to 25, can I setup them more than 25? or any suggestions?
balaji.bandi
yes, you can use 30 AP to connect in the network.
the best result testing in the environment was 25 to get optimal outcomes.
so if are doing more then 25, then you need to test it.
BB
Optimal outcomes? Could you explain a little bit more?
i mean Optimal - right outcome - 25 suggested to do - as many people tested and worked as expected. (if anything more is added as suggested then you need to test it based on the requirement) as rightly said document do support 50.
BB
